Sealed pilot bearing question?
ratface
07-24-2007 13:03:03
My new pilot bearing is sealed on both sides. Part number 6203D. Can anyone verify if this is the correct bearing and does it matter which way it goes in?
Indiana Jones
07-24-2007 14:44:15
 Re: Sealed pilot bearing question? in reply to ratface, 07-24-2007 13:03:03
You're fine with that set up. If you had a pilot with an open side, you'd want to put the open side against the engine.
Jerrycpp(WA)
07-24-2007 13:08:07
Any 203 bearing will work in your pilot. Some Fords even used an oilite bushing there. As far as which way, if it's sealed/sheilded both sides, it doesn't matter. I always like the sealed bearing better as you know they aren't going to get crud in them. If it only has one seal or shield, put the non-shielded side against the crankshaft so the seal/sheild keeps the crud out of the bearing. If it is open on one side, pack some grease in there before installation.
ratface
07-24-2007 13:05:38
Can anyone tell me what size bolts to use as guide pins when aligning the engine half to the trans half?
Dan
07-24-2007 17:09:24
 Re: Sealed pilot bearing question? in reply to ratface, 07-24-2007 13:05:38
I have two special bolts just for this - 7/16" X 14 that is 6" long - I cut the hex head off. You could get them shorter - but I like the extra length.
Dan
Jerrycpp(WA)
07-24-2007 13:10:40
I'm going on memory here, but I think they are 7/16 USS. Just get the same as hold the tractor together, only longer - I like about 4 inch. Cut the heads off, put a slot in for a screwdriver, and put it together.
ratface
07-24-2007 13:35:30
 Re: Sealed pilot bearing question? in reply to Jerrycpp(WA), 07-24-2007 13:10:40
many thanks Jery, I'm several hours away from the tractor and thought I could pick them up tonight.
Jerrycpp(WA)
07-24-2007 13:59:50
 Re: Sealed pilot bearing question? in reply to ratface, 07-24-2007 13:35:30
Okay, in that case, I went out and pulled one out. Yes, they are 7/16 USS. Have fun tonight!
