adding a proofmeter
8n/9n
07-25-2007 16:54:27
Hi, I have a 9N and it has an 8N engine in it. With a side mount Distributor. I would like to know if it is possible to add a proofmeter to this tractor and how much work is it to do it. Thanks Ben
8n/9n
07-25-2007 18:13:58
 Re: adding a proofmeter in reply to 8n/9n, 07-25-2007 16:54:27
How could I locate the proofmeter shaft on the govoner.
Hobo,NC
07-25-2007 19:06:38
 Re: adding a proofmeter in reply to 8n/9n, 07-25-2007 18:13:58
Remove the gov. shaft if its hollow on the rear of the shaft and most are I have the drive pin that goes in the hollow hole. You then would only need the gov. housing that the proof meter cable screws to, you may already have it. You then could run a proof meter off the gov. how you hang the meter may B a different story.
Dell (WA)
07-25-2007 18:24:44
third party image
heres a picture of the governor cup. See the oil hole on top? See the round thingy in the middle? that is the proof meter drive cap that hides the proofmeter drive tang that drives the speedometer cable that drives the proofmeter.
All replacement governor cups have the proofmeter drive capped off. All you haffta do is unscrew the cap, just like a bottletop, and there is the tang. Simple, eh?..... .Dell
Hobo,NC
07-25-2007 19:00:42
 Re: adding a proofmeter in reply to Dell (WA), 07-25-2007 18:24:44
Tang, whut in tar nations izz a tang, izz'zit enny thang close to a TEAT
Dunk
07-25-2007 19:08:10
 Re: adding a proofmeter in reply to Hobo,NC, 07-25-2007 19:00:42
"izz'zit enny thang close to a TEAT"
I like a good TEAT when it's hung in tha right place...
Have to pullem at least twice a day...
Dunk
07-25-2007 19:10:12
 Re: adding a proofmeter in reply to Dunk, 07-25-2007 19:08:10
Mammaries, Mammaries....
Seems to brang back some good memories...
ZANE
07-25-2007 17:21:20
If it has the governor with the Proofmeter drive all you need is the cable and meter and a bracket to mount it.
I don't know if there would be room anywhere on the dash to mount it but a bracket could be fabricated to mount it to one side of the dash.
Zane
Ken Crisman
07-25-2007 18:30:47
 Re: adding a proofmeter in reply to ZANE, 07-25-2007 17:21:20
And I just happen to have a nicely primed & ready to paint 8n dash with tach hole to sell . Email me if interested . God bless , Ken
