Governer Adjustment
2Nnewbe
07-28-2007 17:21:20
I just replaced the governor and am having difficulties getting everything adjusted. When I put the throttle in idle position the governor rattles as if the balls are loose. If I move the throttle a little, giving it a little gas, the rattling noise goes away. The stop screw bottoms out with the throttle only ¾ of the way engaged. I do see how that can be adjusted but just not sure enough to unscrew the stop bolt at this time. Can anyone give me some advice on these challenges?
Thanks in advance,
2Nnewbe
