rear hydraulics problem
Roger Harrison
07-30-2007 08:40:50
the rear hydraulics on my 2N quit working while I was plowing a ditch. I hit a root. The lift arms have no pressure on them. I can lift and lower them by hand. Is there a shear pin somewhere? Or did I blow the pump? any help please.
Roger
tominnebr
07-30-2007 16:19:10
 Re: rear hydraulics problem in reply to Roger Harrison, 07-30-2007 08:40:50
From how your problem occurred my bet would be a broken piston in the Hyd lift cyl.
Dunk
07-30-2007 15:34:47
Try opening the inspection plate on the right side and then lift the lift and see if you can see where the fluid is leaking.
Before you do this make sure your PTO is engaged.
richmond in
07-30-2007 14:26:09
Im no expert but from what i understand it my be your presure relief valve. hang in ther and someone here can tell you for sure. good people here and very helpful.
