My Crystal Ball is Cracked
A. Bohemian
07-30-2007 12:03:27
It is very difficult to guage from your posts, Bob, how much experience you have. That makes it hard to give good, efficient suggestions.
Quote: ''Could I have fired the coil? How do I test that?''
I usually test a coil by substitution. Most coil failure occurs under DYNAMIC (engine running) conditions, with very HIGH voltages induced across the coil secondary. These high transient voltages are difficult to track with a test light or volt-ohm meter. (If you happen to have and know how to use an oscilliscope, that's different; but if you knew that, the odds are you wouldn't be asking how to test a coil).
Before you go screwing and unscrewing things, check your dashboard ammeter for normal operation. It can tell you lots about the points and give you limited info about the coil.
A. Bohemain
07-30-2007 14:47:47
 Sorry in reply to A. Bohemian, 07-30-2007 12:03:27
Quote: ''It is very difficult to tell, Bob...''
Sorry, guys. I meant to say ''Rick.'' Bob's post tells us how much experience he has.
I wish I could learn to type and think at the same time!
