Order Ford 9N Parts Online
9N front axle support
RJ
07-31-2007 08:32:29
third party image
Hello all, I have spent 3 weeks ordering parts and pieces, The 9 runs like a champ with all the needed attention. Now it's about time for the oil pan change. But the 9 had a loader at one time and as with the oil pan, the front axle support is one welded up hunk of iron with more cracks showing. I looked at Ebay and bought this one before I took a good look at mine and they are different, is this one, i won, a 9N support? is it different from a 2N-8N will they interchange? Thanks for the help, RJ
TheOldHokie
07-31-2007 10:30:07
 Re: 9N front axle support in reply to RJ, 07-31-2007 08:32:29
That is the original style used on 9N's from 1939-1941 or there abouts. It will work fine but requires the early style axle pin, 9N-3126A, which is NLA. See this thread just a bit below: 9N Axel Support
I make and sell copies of that pin. Give me a yell if interested: TOH's eMail
TOH
RJ
07-31-2007 14:44:17
 Re: 9N front axle support in reply to TheOldHokie, 07-31-2007 10:30:07
Thanks for all your help, seems my sheet metal has also been updated, so i must use the newer style, the seller also had one so I lucked out! RJ
RJ
07-31-2007 08:44:53
third party image
Mine is like this one from Smiths site, he says its for a 2N-8N. Hence my cornfusion over which I need!
