2N -PTO spins in what direction?
Ron Grzywacz
08-01-2007 07:39:54
Someone asked me this question. If I'm standing behind a 2N tractor. Which direction is the PTO Shaft spinning - Clockwise or CCW. Also what is the standard size of the PTO shaft on the 2N.
Thanks, Ron G.
souNdguy
08-01-2007 11:32:49
 Re: 2N -PTO spins in what direction? in reply to Ron Grzywacz, 08-01-2007 07:39:54
Bob gave you good info.
I'll add that while the 2n 'standard' shaft was 1 1/8"
The common 100$ replacement is 1 3/8".. and you need to check what you have if you are trying to match stuff up..
Soundguy
Bob
08-01-2007 07:46:38
CW as viewed from the rear. It is driven from the transmission countershaft, which is driven from the transmission input shaft by a pair of gears, reversing the direction from that of the engine, Original shaft size was 1-1/8", 6-spline.
