Yow!
A. Bohemain
08-01-2007 08:06:40
Quote: ''charges at about 30 after starting, drops to 20, then 15..half that with lights on. Is this normal?''
If the solid-state voltage regulator is doing its job correctly, you shouldn't see much more than a slight flicker on your dashboard ammeter when you turn on the lights.
Moreover, (and assuming the battery is in good shape) the charge rate should drop to near zero after a couple of minutes or so under normal working conditions.
Take the alternator to Pep Zone or wherever and have it tested.
A. Bohemian
08-01-2007 08:13:51
 Oh, yeah! in reply to A. Bohemain, 08-01-2007 08:06:40
I should have added, if the alternator tests ok on the stand, double check all your wiring connections, especially grounds. The internal voltage regulator in most alternators won't work well unless properly grounded, with the correct polarity.
