No one can give you accurate advice on the resistor without knowing the actual primary resistance of the coil you get. There are several variations on the market nowadays, from the "land of almost right", I guess. The bottom line is that you need enough resistance ahead of the coil to limit the primary current to not much over 3 Amps, and DEFINITELY not over 4 Amps. This is with the ignition switch "ON", the engine NOT running, and the breaker points CLOSED. PLEASE reconsider getting a one-wire alternator. A standard 3-wire unit is really easy to connect up, and CHEAPER, and performs BETTER. You just need a Delco 10SI alternator, and a diode or "idiot lamp" to connect it up. The diode or the lamp can be used interchangeably. The current draw through the ignition switch will be LESS than 5 Amps, UNLESS you power headlights through it. Do you have an 8N chassis or a 9N chassis? The 9N starter switch carries the full current draw of the starter, somewhere between 100 and 200 Amps. The 8N tranny-top mounted neutral safety starter switch carries only the current needed to activate the solenoid, less than 10 Amps. Which ever tractor you have, I HOPE you'll retain the functionality of the neutral-safety starter switch!
