Torque Specs
apbmalibu
08-02-2007 04:11:21
Is there some place online that lists the torque specs for a 2n Ford? I"m rebuilding the hydraulics...
skycarp
08-02-2007 07:28:26
 Re: Torque Specs in reply to apbmalibu, 08-02-2007 04:11:21
[quote:51002d0167]Is there some place online that lists the torque specs for a 2n Ford? I"m rebuilding the hydraulics...[/quote:51002d0167]
Available on line here:http://www.raskcycle(dot)com/techtip/webdoc14.html
Replace the (dot) with a period and go to the site.
Print it out and take it with you to your shop.
I use this small pocket reference when in the shop.
third party image
Available here:http://www.amazon(dot)com/exec/obidos/ASIN/1885071337/bookstorenow57-20
HTH
souNdguy
08-02-2007 05:14:21
If you are looking for fastner torque specs, look in your FO-4 manual. That's where i found mine when rebuilding my hyds.
If ya don't have a manual.. get one.. it's a great help.
You can always use a standard torque chart as well.. Treat the bolts as gr5.. and check a chart.. i believe the bolts are 7/16... here's a link to a pdf.. bolts are about a page down..
Soundguy
