You have three chambers, all using the same oil. I don’t think you want to run diesel to liquefy that sludge, and then run it through your moving parts like bearings and pump chambers. Best to remove it out the bottom. With the working parts in the three cavities still in place, you can only expect to lower the volume of sludge, not eliminate it. Myself, I took off the transmission cover, hydraulic lift top cover and removed the pump and PTO shaft. All drain plugs were out. The sludge in mine was the consistency and color of peanut butter. I used a steam cleaner, a pressure washer and a solvent gun in that order. The pressure washer was the most effective. One location you will not have much luck with in the rear axle trumpets. I tilted first one side then the other to allow the liquid to flow out. To my advantage, I was replacing the axle seals on one side so I had a straight shot into the trumpet on that side. After the steam and pressure washer there was a little flash rust in some locations, but for the most part, the metal is saturated with oil molecules and rusting was not a problem for the short time it was without oil on the moving parts. While in there, I replaced the lift cylinder, and a new NAA piston and ‘O’ ring and leather gasket. I also installed a new relief valve on the pump. With clean new oil, the pump was quite and the lift arms stayed up all night! Good luck.
