crack block oil leak
RJ IN WYO
08-05-2007 10:50:29
Have been rebuilding my 8n the last few months. you guys have gave me some good advice. need some more but i think i know the answer but someone might have a trick out their. after getting my 8n put togather and all the new parts i have bought put oil in the block getting ready to start up. about 25 years ago the oil pan cracked and my dad had it welded didnt leak a drop a oil in 25 years. after geeting it back from the machine shop it open up and is leaking. i figure ican split the tractor again and get a new oil pan. or could a person use some JB WELD since it supose to be so could at sealing. after all my work i hate to take two step backwards since im so close to starting her up. any suggestions would be helpful but i think im going to have to bite the bullet and tear it apart and reweld or replace the oilpan thanks rj in wyo
john hunt
08-05-2007 14:39:31
 Re: crack block oil leak in reply to RJ IN WYO, 08-05-2007 10:50:29
where it leak at in front or rear or middle of the pan, bottom of motor or the top of motor ??
RJ
08-05-2007 11:09:40
OK, If your like me, and you are, I spent 20.00 bucks and bought a good used one, The oil pan is part of your frame. If you fix the oil leak, you still have a poor frame. Seeing we are both RJ, we both live in Cheyenne, we both have Ford tractors, What the heck is your name? I live out on Fox Farm Rd. BTW my oil pan was cracked and leaking from a old repair, bet your tractor once had a loader on it... This is bizarre to say the least.
RJ IN WYO
08-05-2007 12:39:43
 Re: crack block oil leak in reply to RJ, 08-05-2007 11:09:40
hey RJ WHAT A SURPRISE. I was looking in the archives and i beleive i ran across a picture of you working on a oil pan. got the phone book out and called all the ron jones. must be unlisted. my name rich juschka. i live across the road from the port of entry on south greeley hwy im in the phone book give me a call. i have 3 8n a jublee, a 801 and a 4000 a wd ac looking forward to hearing from you
RJ
08-05-2007 17:31:08
 Re: crack block oil leak in reply to RJ IN WYO, 08-05-2007 12:39:43
third party image
Yes i'm unlisted. I have one of the VOIP phones so they leave me out of the book. I'm easy to find, there's a 1951 Ford business coupe, also a 1935 Diamond-T out front for sale. Also the only barrow ditch with a touch of color...
Bob
08-05-2007 11:16:02
 Time to key up the Twilight Zone Music! in reply to RJ, 08-05-2007 11:09:40
Bob
08-05-2007 10:54:51
If the leak is simply through a pinhole or flaw in the old weld, and NOT a crack, it would just seal it up.
IF the pan and crack were clean, and not oil-soaked, JB would do the trick.
I would take the pan off, degrease it as much as possible, then heat the cracked area with a torch to burn off all oil. When it cools, wire brush the cracked area, then put JB weld on the INSIDE.
That would HOPEFULLY make a permanent oil-tight repair.
