GREAT NEWS!!!!!But............
SOB
05-18-1999 05:37:32
Yeehaw!!! My 9N is finally starting!!!! Thanks to everyones help in here. I just changed the battery cables and recharged the battery and....vroom! It started right up....But....I think I messed up my overrunning coupler. Should I be able to turn it at all when the pto is engaged? Cause I can't.Off the tractor it turns one way when I do it by hand. Is it busted???
John C.
05-18-1999 07:55:20
 Re: GREAT NEWS!!!!!But............ in reply to SOB, 05-18-1999 05:37:32
Mine has a rollpin that needs to be centered in the body of the unit when it's assembled to the pto.
You might remove the grease fitting and the screwplug opposite it and check to see that the pin is the same distance on both ends from the outside diameter of the unit.
If you've replaced the rollpin for some reason, it might be longer than the original.
