Order Ford 8N Parts Online
8n Question
Ben Kiessling
08-06-2007 12:35:50
I'm looking to buy an 8n. I looked at it and when i opened the radiator cap, all that is in there is motor oil. The owners says its a bad head gasket, but i want someone elses opinon before buying it. Anyone who could help me out would be most appreciative.
Thanks
A. Bohemian
08-06-2007 13:35:23
 Bad Gasket? Yep. in reply to Ben Kiessling, 08-06-2007 12:35:50
Quote: ''I looked at it and when i opened the radiator cap, all that is in there is motor oil. The owners says its a bad head gasket...''
What you saw no doubt looked like motor oil; but it may well have been combustion products suspended in the coolant. This is indicative of a bad gasket and implies the owner is at least being honest with you about that.
Indiana Jones has an important point about that oil. Oftentimes a head gasket on a flat-head will blow with no lasting effects; but IF water did get in the oil and IF the tractor was run with water in the oil this one is potentially a rebuild candidate.
Indiana Jones
08-06-2007 13:12:25
 Re: 8n Question in reply to Ben Kiessling, 08-06-2007 12:35:50
Check to see if there's water in the engine oil, or if the oil is perfectly clean (just been changed). If I saw either, I'd pass (unless you can get it real cheap).
JMO
Ramon
08-06-2007 12:56:33
Will it start & run?
Next, #1 compression test for all cylinders
#2 Pressure test for the cooling system
#3 Condition check for rear rims & wheels
#4 Verify year
#5 Condition of PTO & Hydraulics
