Flushing Gas tank and Radiator
Chris S.
08-06-2007 15:45:53
The local radiator shop no longer boils gas tanks or radiators, if I run hot water straight out of my water heater and spray the water through with the water hose would that do the trick? Thanks
A. Bohemian
08-06-2007 17:17:12
 Try an Aircraft Shop for the Gas Tank in reply to Chris S., 08-06-2007 15:45:53
The labor can be a few more $ per hr., but the standards are often higher.
old
08-06-2007 15:50:59
 Re: Flushing Gas tank and Radiator in reply to Chris S., 08-06-2007 15:45:53
Can't say on the gas tank but on the radiator put the cap on lay it flat and fill with vinegar, let it sit 24 hours or so then flush with hot water and that should clean out most of the stuff.
