hydraulic pistons
49ford
08-08-2007 12:55:21
I'm getting ready to overhaul my hydraulics. What piston is best for sealing and lift power on 8n?
Ramrod
08-08-2007 14:12:30
 Re: hydraulic pistons in reply to 2nNewbe, 08-08-2007 12:55:21
It is a good idea to replace the piston with the NAA style if the cylinder is not too badly scored, but do hone it out beforehand. The trick is to avoid the leather backup washer and use the rubber backup washer instead. If you do use the leather backup, be sure to soak it well before you try to install it as they like to tear on install.
Ramrod
third party image
souNdguy
08-08-2007 14:09:41
 Re: hydraulic pistons in reply to 49ford, 08-08-2007 12:55:21
As mentioned.. if you use the new piston and oring.. hone your old cyl if it has mild pitting or scratches.. if heavy.. then get a new cyl.
soundguy
Marks8N
08-08-2007 13:50:28
I belive if my memory has not faailed or twisted, I have seen that most prefer the one for the NAA with the rubber o rings it will fit and last longer.. The guys here will have a few sugestions or opppions for the correct parts. Well lets here it from the Ford specifers.
Bene
08-08-2007 14:06:23
 Re: hydraulic pistons in reply to Marks8N, 08-08-2007 13:50:28
Its the new style with the 0 ring according to the tractor repair dealerships that I have talk to.
You might not want to use it however unless your putting in a new cylinder also. Seems that used cylinder usually have some scaring and the 0 ring type may not last very long.
