1, are you using metal core wires or carbon core wires? Carbon core wires are for modern automobiles with radio's and other electronic gizmos that are affected by spark noise... they also cut spark intensity... that don't matter much on modern HEI spark systems. However on your old anemic spark system.. you need all you can get. You do know that it's a 2-bolt job to remove the distribuitor and set points and static timing on yer bench right? A cheap reprint owners manual will help you as well as a copy of the I&T fo-4 manual. In any case.. the timeing issue isn't real bad.. generally even if you are out of adjustment.. if all else is good.. they will at least start. Also.. gently stretch the pigtail spring under the coil to make sure it makes good contact with the ponts screw.
Veryify you have points opening and closing by 1 of 2 ways. #1, with a test lamp. Turn ignition on, connect test clip to wire that would go to coil, remove coil, put probe to points screw.. roll engine over.. lamp should blink. If it stays off.. poitns aren't grounding.. or you aren't getting power. If it stays on.. points are shorted or are not opening... points DO slip.. #2, with an ohm meter... use continuity beeper on a digital.. or look for low range / needle swings on an analog. Remove coil, put one probe to ground, and one probe to points screw.. roll engine over.. listen for beeps.. or look for needle swings. .. same info as above if no swings.. or constant beep.. etc.. lastly.. make sure you have between 2.5 and 3.5 v at the wire for the coil, when it is installed, with points closed. Prime location for loss of voltate is a bad ignition switch.. and / or bad dirty contacts and old wiring between the switch and ballast resistor.
Soundguy
