Order Ford 8N Parts Online
8n hyd pump
omar
08-09-2007 22:03:08
Can anyone tell me where to get a parts diagram for the hydraulic pump off of an 8n
Dunk
08-10-2007 15:35:04
 Re: 8n hyd pump in reply to omar, 08-09-2007 22:03:08
third party image
James Shepherd
08-10-2007 13:17:58
Please let me know how you are doing with this. I had to rebuild mine with just the diagram in manual I have. I would liked to have a better diagram but it was all I had. Got lucky and mine seems to be working ok now. Hope yours goes as well. Jim
omar
08-10-2007 20:48:52
 Re: 8n hyd pump James in reply to James Shepherd, 08-10-2007 13:17:58
Hey James, I hope I have the same luck you did. I am gonna get started tommorrow. The original problem on my 8n was the differential gear and the pinion shaft. To take the pinion off I had to break the rear end off the tractor so I thought this was as good a time as any to rebuild the hydraulic pump. It was actually working pretty good. It would just drift down after a while with a shredder attatched. What parts did you use to rebuild yours and where did you purchase the parts? I would appreciate any other advice you might have. Thanks.
gahorN
08-11-2007 05:31:00
 Re: 8n hyd pump James in reply to omar, 08-10-2007 20:48:52
That AIN'T THE PUMP that allows the 3-pt to drift down. It's the piston/seal at the RAM. Use the later rubber piston/ring and you'l be happy.
ZANE
08-10-2007 12:20:15
Click on the link below.
Zane
Dan
08-10-2007 04:38:46
You can find these at the New Holland site, click on parts.
Dan
