Hi Guys and Gals,I just got the old spindle bushings out of the front axle sections, mostly by using a very small chisel to split them from the backside. Now first thing in the morning I'll be putting the new bushings in. What tricks should I know for this task? Will they usually just tap into place, or should I freeze them or maybe use dry ice? I haven't tried the fit yet, so maybe I'm just worrying over nothing. The new ones are the FNH part. I spent a lot of effort trying to get the remains of the old thrust bearing out of the spindle. It looked like it had become welded in place, and was so hard that a chisel wouldn't touch it. Finally I remembered a trick that an older Cat mechanic had shared. They often take out old bearings with an arc welder. I ran a bead around on the old groove where the bearing balls would ride, as it cooled it shrinked and came out pretty easily with a little hammer and chisel action. Thanks for your ideas on the bushings. Paul in MN
