how to tell mower differences
rd99
08-14-2007 18:18:25
How do I tell if a mower is a finish mower or not? I've got a Covington mower that's somwhere around 60 years old. It's got a tail wheel. The blade center is probably a 2-3' disc and there are two cutting blades attached to the edge of the disc opposite each other.
JMOR
08-14-2007 19:31:57
 Re: how to tell mower differences in reply to rd99, 08-14-2007 18:18:25
Blade speed is considerable different too.
In general round numbers:
heavy brush cutter 10,000fpm
std brush & pasture weeds 14,000fpm
finish mower 16,500fpm
Tom N MS
08-14-2007 18:25:20
You have described a rotary cutter with a stump jumper. A finish mnower usually has three blades driven by a belt or two from a gearbox.
Bob
08-14-2007 18:25:12
You have a "brush cutter, rough-cut mower, "Bush Hog" or whatever the commonly-used term is in your region.
A "finishing mower" will typically have multiple spindles (often 3), and just be a bigger, heavier version of the mower deck under your Gramma's Krapsman.
