Tractor id
Red
05-18-1999 16:38:10
I know about the number on the engine block,but mine has two different numbers. The original which is barely visible and a number that has been stamped directly underneath the original. From what I can make out of the original number it is not the same as the stamped one. Is there another location that the number is on the tractor? Appreciate the help!!!!
bg
05-18-1999 17:16:23
 Re: tractor id in reply to Red, 05-18-1999 16:38:10
There is no other serial number location. There are casting numbers that may give you clue. I surmise that your engine might have been replaced and someone stamped the number of the original block below the other one so they could remember the original year.
