valuable rear hubs?
arthur ward
08-15-2007 22:19:12
local N repairman mentioned something about some N rear hubs worth $500 each. I guess the rear hubs without all the bolts he was talking about. Anyone know what years/style N he means?
Dell (WA)
08-15-2007 22:28:49
 Re: valuable rear hubs? in reply to arthur ward, 08-15-2007 22:19:12
third party image
Authur..... ...you mean this???..... ..Hub - Rear Axle Hub 8N, NAA, Jubilee. With Studs. (Part No: 8N1171) $59.90
He must think you just fell off the turnip wagon. That must be his "shop rate" for replacement. ..... Dell
arthur ward
08-15-2007 22:43:02
 Re: valuable rear hubs? in reply to Dell (WA), 08-15-2007 22:28:49
dell, on a 2N it has the larger center hub that the rim bolts to. i guess its the center section without the bolt pattern that is rare and valuable. supposedly not common at all.
Dan
08-16-2007 02:12:17
 Re: valuable rear hubs? in reply to arthur ward, 08-15-2007 22:43:02
third party image
Sounds like you are talking about the original early ('39 & '40) 9N smooth centered hubs. They did not have the riveted ring in the center like you see on 95% or more of the 9N and 2N tractors today. They were smooth because they were butt welded to the axle shaft. However, this design was prone to breaking under load and that us why they went to the riveted ring design for extra strength. Because they only made these smooth hubs about a year, and because so many failed in the field, there are few survivors - that is what drives the cost up.
Here is a pic of my '39 9N - it had one smooth and one riveted hub when I got it. I finally found another smooth hub, but it cost me $275 for it.
third party image
HTH,
Dan
arthur ward
08-16-2007 06:47:03
 Re: valuable rear hubs? in reply to Dan, 08-16-2007 02:12:17
thanks dan, i guess this N repair guy wasn't pullin any legs after all.
according to him, he gets $500 a hub, when he finds one. so far he found 4 i guess. i think i'll have to start combing the country side a little bit more. maybe i can get lucky also.
anyway, my brothers 2N makes a howling sound when in gear and driving. always had it since he bought it last year. it sounds like it is coming from the clutch area. no howling when the clutch is in so i assume it wouldn't be the throwout bearing. the motor was rebuilt a few years ago and sounds absolutely beautiful and has a nice slow idle.
one thing is that it has i think a 6 blade fan and my 8N has a four if i remember right. any thoughts on that?
don b
08-16-2007 09:55:32
 Re: valuable rear hubs? in reply to arthur ward, 08-16-2007 06:47:03
Arthur....your tractor came with the 6 blade fan.All 9-2-8ns came with 6 blade fan after 1940 and up to Oct.1948. don b
Dan
08-16-2007 07:41:51
If the howling is when the tractor is in motion (or when the clutch is spinning) then your problem would not be the throwout bearing. A throwout bearing howls when you push the clutch pedal down to disengage the clutch.
Most likely, if it coming from towards the front of the tractor, it would be a input shaft or pilot bearing. If one of these are pitted, chances are all of your tranny bearings and cups are pitted and needs to be replaced. On a 9N/2N tracor, that is really pretty easy - I just got finished doing this on my '39 9N. One other thing, if it is an early 9N, the tranny had straight cut gears (not angled like almost all of them are). Straight cut gears make quite a bit more noise when turning - this is why they went to the angle cut gears.
HTH,
Dan
arthur ward
08-16-2007 08:58:30
 Re: valuable rear hubs? in reply to Dan, 08-16-2007 07:41:51
dan, it is a 47 2N. yeah, i know about the engagement of the throwout bearing. i figured it wasn't the problem. he'll crap his pants if he has to break the tractor in half to get to it. maybe he will let it go or take it in to get it fixed. how long before a major problem with it?
