Leaking Sector Arm
Rush-N
08-17-2007 06:19:14
third party image
Any tricks or information to repairing the leak I have running along the backside of the pictured Sector Arm. I have the Dust Felt Seal (8N-3585), 1 Piece Retainer and Seal (8N-3591-B) and the Steering Gear Pitman Shaft Bushing (8N-3553). Tightening the big nut only slowed down the leak. The leak is small but annoying. Anything else it could be? Thanks, Rush :)
Ramrod
08-17-2007 08:39:53
 Re: Leaking Sector Arm in reply to sgtbull, 08-17-2007 06:19:14
Do you have JD Corn Head grease in there?
Ramrod
third party image
Rush-N
08-17-2007 12:49:35
 Re: Leaking Sector Arm in reply to Ramrod, 08-17-2007 08:39:53
This is the fluid that came with the tractor when I got it so I am not quite sure if it has the Corn Head Grease, but probably not since it is leaking. I do have the Corn Head grease on hand and will replace after my repairs. Will most of the fluid be drained when I make the repairs? Thanks, Rush :)
new2ns
08-17-2007 07:34:36
 Re: Leaking Sector Arm in reply to Rush-N, 08-17-2007 06:19:14
first do you have any shaft play?..if so you need to replace the bushing and check the shaft for wear. If no shaft play is present remove nut and arm, replace seal ( personally when I replace the seal I slightly pack the back of the seal with wheel bearing grease ( just a small ammount behind lip) lube the shaft then install the seal with sealer (I use locktite bearing and flange sealer)on the outside edge . then install dust seal. In my experiance 9 out of 10 times bushing is worn causing excessive play and then the seal leaks. hope this helps..
cheers
Rush-N
08-17-2007 08:13:16
 Re: Leaking Sector Arm in reply to new2ns, 08-17-2007 07:34:36
Thanks for the response. My steering works great and has NO play, just an annoying leak. Is the Sector Arm and Seal pressed on? If so, any suggestions to remove the arm without damaging the paint. Thans, Rush :)
dan hill
08-18-2007 02:59:45
 Re: Leaking Sector Arm in reply to Rush-N, 08-17-2007 08:13:16
The steering arm is a tapered splined fit, there are 2 seals to replace,it would be easier to wipe the oil off from time to time.
new2ns
08-17-2007 09:04:33
Best of my memory its a taper fit, don't think you can get her off with out chipping the paint some...but try turning the nut off using a hand wrench or scocket but do not use a air wrench.....unless you have an auto motive bearing type puller... take something like a block of wood and get on the back edge of the arm and whack it with a hammer somtimes just a tap on the end of the shaft (use block of wood)..sometimes they just pop off sometimes not.... just take it slow and use tape and a rag or two may help....protect it where you can...
cheers
