Steering Arm Ball Joint
Art in Cortez,
08-17-2007 20:24:28
Hi All,
Thanks for your help in the past it has been truly great.
I want to replace the dust boot on one of my front steering arms but the the nut on the bottom will not break lose. The tapered shaft just spins when I turn the nut. Any tricks I can use to get the nut lose and remove the ball joint from the steerting arm?
Thanks in advance for any ideas anyone might have.
9NJoe
08-18-2007 16:25:11
 Re: Steering Arm Ball Joint in reply to Art in Cortez, Co, 08-17-2007 20:24:28
Art,
Try an impact wrench, Hopefully the impact will get it loose.
Joe
old
08-17-2007 20:44:04
Theres a few way that might work. 1 is to clamp the arm down tight so as to press the joint tighter. 2 is to use thin vise grips to clamp onto the shaft and then take the nut off. 3 take a hammer and hit the top of the joint a few times and some times that will lock it also. Now none of these thing will work for sure just some ways I have done it in the past.. You can also get a nut splitter and that will do it for sure but then you also need to get a new nut and maybe work on the treads on the joint
