removing spindle key
rbrhea1
08-18-2007 07:14:42
I can,t get my spindles apart on my 2n.I can,t et the key out?Do I just keep driving it down and the key will fall out? Thanks for any help.
Indiana Jones
08-18-2007 08:41:09
 Re: removing spindle key in reply to rbrhea1, 08-18-2007 07:14:42
Soak it good with penetrating oil, let it sit a while, the take a punch and hammer and tap on each end GENTLY at first, then gradually hit harder if necessary. That how I got one of mine out that was stuck. The other side came out no problem
rbrhea1
08-18-2007 14:25:36
 Re: removing spindle key in reply to Indiana Jones, 08-18-2007 08:41:09
does the key have to come out to knock the spindle out? or can you just keep knocking it through with the key in and then take the key out.I thought that the key was just for keeping it in place from side to side?
Indiana Jones
08-18-2007 14:54:45
 Re: removing spindle key in reply to rbrhea1, 08-18-2007 14:25:36
The spindle will not come out without first removing the key. It will most likely come out if you knock the spindle down against the housing, but you might also damage the key in the process. It is a pretty snug fit for the key into the spindle arm. If you flatten the bottom of the key while pounding it may not fit back in the spindle arm channel. Your call. You could also take a length of pipe and put the lip of the pipe between the key and the spindle and hit it the other end of the pipe with a BFH at a slight angle. Should pop out.
