Order Ford 9N Parts Online
1941 9N Speed Test
Sean (TX)
08-18-2007 10:57:09
Conducted this test with the shredder on and in the down position. With the PTO off. Used my handheld GPS to get the speeds. Running at full throttle.
1st and reverse 3.8 MPH
2nd 4.8 MPH
3rd 11.1
Sean (TX)
08-19-2007 06:53:09
 Re: 1941 9N Speed Test in reply to Dunk, 08-18-2007 10:57:09
steveormary said: (quoted from post at 23:44:06 08/18/07) Sean(TX)
You should find the throttle setting that will give you 540 pto rpm. I would think 2200 engine rpm would way over speed the pto. Be careful and have fun.
steveormary
rd99 was wondering what the speed of a 2N was in another post. Had a GPS so I conducted a test..
Sean (TX)
08-18-2007 19:40:18
 Re: 1941 9N Speed Test in reply to tomtoney, 08-18-2007 10:57:09
They are too fast for the most part. I want a over/under drive...
rd99
08-18-2007 18:54:59
 Re: 1941 9N Speed Test in reply to murn ga, 08-18-2007 10:57:09
Sean (TX) said: (quoted from post at 20:18:06 08/18/07) Have a overdrive?
No, I'm sure it's doing the same speed yours is. But it feels a bit too fast for my liking.
Sean (TX)
08-18-2007 17:18:06
 Re: 1941 9N Speed Test in reply to ld5030, 08-18-2007 10:57:09
Have a overdrive? I only go that fast going down hill with the clutch in. I bushhog 5 acres for a camp ground about a mile away. It takes me 15 or 20 minutes to get there... Nice road trip. Up hill all the way back!!...Have a extra transmision shift lever? Standard tranny wont do 30 in third!! Could be you are also missing a shift lever and its in over drive. Have any pics of the left and right side?
rd99
08-18-2007 16:44:14
 Re: 1941 9N Speed Test in reply to Sean (TX), 08-18-2007 10:57:09
I'll have to test mine and see. It feels more like about 30mph in 3rd.
Especially when you hit a bump, I get the "I am going way too fast" thought in my head.
Sean (TX)
08-18-2007 11:26:19
 Re: 1941 9N Speed Test in reply to lonestarjeff, 08-18-2007 10:57:09
I am running 12.4 X 28. I don't have a tachometer. I don't think i am reaching the max 2200 RPM's hard to say without a tachometer..
steveormary
08-18-2007 20:44:06
 Re: 1941 9N Speed Test in reply to Sean (TX), 08-18-2007 11:26:19
Sean(TX)
steveormary
Bill(Wis)
08-18-2007 11:07:10
Any idea as to what your RPMs were? What size tires on the back?
