NAA fuel strainer assembly
AMC
05-18-1999 19:16:33
Does anyone know what size of 0-ring or gasket is required for the valve stem. The unit I have leaks when turned out the proper two turns, but will almost stop leaking when turned all the way out. I know that Steven Tractors sells new fuel strainer assemblies for $18.95, but I believe a 10 cent 0-ring or gasket should fix the leak that is right at the point where the stem enters the assembly. Appreciate any info.
bg
05-18-1999 19:20:03
 Re: NAA fuel strainer assembly in reply to AMC, 05-18-1999 19:16:33
You can buy a repair kit for the stem and seal.
Jim
05-19-1999 03:40:48
 Re: Re: NAA fuel strainer assembly in reply to bg, 05-18-1999 19:20:03
Where? I have a NAA and a 600, both have the valve only fitting under the tank (no sediment bowl) both CT and the NH dealer want $38 for the entire valve.
bg
05-19-1999 06:57:45
 Re: Re: Re: NAA fuel strainer assembly in reply to Jim, 05-19-1999 03:40:48
The 53 Jubilee(and I assume the 54 NAA) calls for a 2N 9155-B sediment bowl assembly which uses an APN-9194 rebuild kit. Tractor Supply has the deal for about $18.95. Stevens has the same thing, $18.95 and the kit is $5.95, stem with wheel complete.
Jim
05-19-1999 19:00:43
 Re: Re: Re: Re: NAA fuel strainer assembly in reply to bg, 05-19-1999 06:57:45
My tractor has the later model type valve, no bowl on it. I have not been able to find any parts for it's valve other than the o ring that goes between it and the tank.
bg
05-20-1999 18:47:34
 Re: Re: Re: Re: Re: NAA fuel strainer assembly in reply to Jim, 05-19-1999 19:00:43
Well, just plunk down $18.95 and buy the right one for your tractor and then you won't have to worry about fixing the wrong one.
Jim
05-21-1999 05:15:12
 Re: Re: Re: Re: Re: Re: NAA fuel strainer assembly in reply to bg, 05-20-1999 18:47:34
I would like too! Problem is the early type $18.95 version screws into the tank. The late version attaches with two bolts and has an o ring under it's flange. It is the screw in valve on it that does not seem available from anyone. It is a different valve than the one that goes into the screw in sediment assembly.
bg
05-22-1999 20:56:02
 Re: Re: Re: Re: Re: Re: Re: NAA fuel strainer assembly in reply to Jim, 05-21-1999 05:15:12
Has someone changed your fuel tank? I wasn't aware that the NAA tank had two configurations. Anyway, go to any good hardware store and get out the o-ring assortment tray. you chould be able to find an o-ring to fit it.
