Get to Know Your Dashboard Ammeter!
A. Bohemian
08-20-2007 11:56:02
Ignition on, no cranking, you should see 3 amps static discharge.
No discharge? Points are not conducting properly, the coil primary is open, or there is another open somewhere in the circuit. (Odds are it's the points.)
Normal discharge? Crank while watching the ammeter. You should see it dip or flutter as the the points open, interrupting the current flow, and then close.
No dip or flutter? Points are not opening properly, are shorted, or there is a short somewhere else in the system.
No dashboard ammeter? Why not? It's one of the most useful things in the world for diagnosing no-start or no-charge problems.
