Loader Controls Placement .... what's right???
AZ GhostTown
08-20-2007 15:27:29
I have two tractors each with a loader. An NAA and Ferguson TO-30. Both loaders are the same design, I believe Dearborn. Controls are mounted on the right side of each with the NAA lift on the inside and tilt on outside. TO-30 just the opposite. Is there a standard? I need to change the controls on one of the tractors to make my life a bit easier.
Thanks,
Mike
soundguy
08-20-2007 17:14:23
 Re: Loader Controls Placement .... what's right??? in reply to AZ GhostTown, 08-20-2007 15:27:29
Ditto what the others said... what ever you want is standard.. ya don't like it.. swap hoses..
I like having the most used control in the most accessable place.. do what's good for you..
Soundguy
ZANE
08-20-2007 17:10:15
Yes there is a standard. The lift is on the left and the bucket on the right on all loaders.
Zane
murn ga
08-20-2007 16:08:51
Just switch the 4 hoses.
TheOldHokie
08-20-2007 15:41:19
AZ GhostTown said: (quoted from post at 15:27:29 08/20/07) I have two tractors each with a loader. An NAA and Ferguson TO-30. Both loaders are the same design, I believe Dearborn. Controls are mounted on the right side of each with the NAA lift on the inside and tilt on outside. TO-30 just the opposite. Is there a standard? I need to change the controls on one of the tractors to make my life a bit easier.
Thanks,
Mike
There is no standard. Personally I love the way my joystick handles third party image
TOH
