Order Ford 8N Parts Online
Does wagner loader for 8n fit Jub
AndyW
08-21-2007 18:48:46
I have a Wagner Front end loader (pipe) for my 8N, will it fit on a Jubilee?
Thanks, Andy
soundguy
08-22-2007 11:40:50
 Re: Does wagner loader for 8n fit Jub in reply to AndyW, 08-21-2007 18:48:46
If you got a torch and welder.. -any-thnig will fit.
soundguy
Hobo,NC
08-22-2007 04:20:06
third party image
It should, the jub is 5" are so longer. On mine the rear mounts are drilled to go on a Jub, NAA. The front supports are pert neer identical. It should not B a problem to install on yer jub.
old
08-21-2007 20:05:48
Yes , no or maybe. Depends in the bracket you have with it etc. The N series are a little short then the jubilee is so it depends on the mount on it as to if it will be a bolt right on or if you need to modifie it
