2n radiator
Richard from SE
08-21-2007 21:33:51
Need some radiator info. I got the engine rebuilt on my ole 2n and when my mechanic went to put the radiator on, the top came loose. Just as well replace it. Can't find a good old one so I guess I'll go new. The most reasonable (read cheap) is chinese made. Don't know how good they are and don't care. I try not to buy anything chinese. So,does any one know anything about the Clancy brand? The filler neck looks to tall. Wouldn't that put the cap to high over the hood? How about "Buy it now" on ebay. Some are advertized as not chinese made but they don't say where they are made. Where do I go guys.
paulf
08-22-2007 11:30:57
 Re: 2n radiator in reply to Richard from SE AZ, 08-21-2007 21:33:51
Hi,
Clancy's are made in Ireland. Also an import...But at least they'll have a pint with ya!
Paulf
soundguy
08-22-2007 11:19:09
I have an indian made radiator.. and I believe there are some turkish units out there.
Unfortunately.. you choices on aftermarket parts are becomming limited by country of origin..
Soundguy
SteveB(OH)
08-22-2007 06:31:20
Richard,
I posted about my radiator a few weeks ago, and I learned some valuable info.
My radiator is an aftermarket that is much like a car radiator. It has small tubes that are close together with thin metal heat conductors pushed in between the tubes. This results in a very poor radiator for a tractor because chafe & dirt clog the radiator in short order.
I forget the exact term, but the proper radiator is called something like an "industrial core". It has wide spaces between the tubes & fins so that dirt doesn't get stuck and clog the radiator up.
I would strongly recommend that you install that type of radiator.
For my part, I try to blow out my radiator with compressed air several times a season. It's amazing how much junk comes out.
