Order Ford 8N Parts Online
2N With A 8N Engine Front Mount Distributor
Sean (TX)
08-23-2007 15:37:27
Has a 12 volt conversion. Does it need a ballist resistor if it has 12 volt coil?
Sean (TX)
08-23-2007 16:21:20
 Re: 2N With A 8N Engine Front Mount Distributor in reply to LaVern, 08-23-2007 15:37:27
third party image
Sean (TX)
08-23-2007 16:02:52
Got it...Thanks
GB in MT.
08-23-2007 16:01:21
 Re: 2N With A 8N Engine Front Mount Distributor in reply to Sean (TX), 08-23-2007 15:37:27
I just sent ya two emails with diagrams.
Enjoy
Garythird party image
Tom N MS
08-23-2007 16:13:24
 Re: 2N With A 8N Engine Front Mount Distributor in reply to GB in MT., 08-23-2007 16:01:21
I'd like to see it too or is it top secret?
GB in MT.
08-23-2007 18:54:15
 Re: 2N With A 8N Engine Front Mount Distributor in reply to Tom N MS, 08-23-2007 16:13:24
Hi Tom; I see Sean already gave ya what you wanted to see. No big secret, just easier to send to him direct.
Keep "N"in'
Sean (TX)
08-23-2007 15:52:31
 Re: 2N With A 8N Engine Front Mount Distributor in reply to gahorN, 08-23-2007 15:37:27
Ill have to find out. It is not my tractor. Im sure he has a car or truck ballist resistor now!! Going to lend a hand Sunday and see if we can start it...
Tom N MS
08-23-2007 15:43:52
Dell's explanation to me just a few days ago.
Tom..... ...I can't exactly answer yer coil question. The early 12-volt coils 1997? were "touted" as being 12-volt coils and it became very evident within about 6-mos that they were MELTING because the 12-volt alternators were pumping out 14.7 volts and OVER CURRENT the internal coil resistance. They started inculding a little piece of toilet paper that said to add a 0.47-ohm resistor to LIMIT the coil current. ONLY electornic engineers like me, know how and where to get 0.47-ohm resistors. NOT from TRACTOR stores or autoparts stores; Industrial Electronic stores. I devised my "trick resistor" from generally available RatShak resistors. Two 1.0-ohm 10-watt resistors in parallel turn into 0.5-ohm 20-watt resistor. Its the LAW! And the difference between 0.47-ohm and 0.5-ohm is???? not much.
So do you have the early 12-volt coil (about 3.5-ohms) that need my "trick resistor" or do you have the later 12-volt coil (about 2.5-ohms) that needs the OEM "infamous ballast resistor". I haven't gotta clue. You will haffta ohm-meter it yerself. BTW The OEM 6-volt coil is about 1.2-ohms. Exact values need LAB grade test meters. Close'enuff is good'enuff.
I hope I answered your questions..... ....respectfully, Dell (WA)
