Re: 41 (N Resistor Block
Sean (TX)
08-23-2007 17:48:25
Dell (WA) said: (quoted from post at 20:40:42 08/23/07) Sean..... ..YES, that little short red wire is BYPASSING the "infamous ballast resistor". And iff'n you think yer ballast resistor is glowing red, there is always the "finger test"..... ..BURNIE-BURNIE..... ..Dell
That going to fry the points or coil or both? replaced points a couple of months ago. The rub bar was wore down and I couldnt get the correct gap. Starts on the first crank and I have several hours on it since the last set of point were installed...
Dell (WA)
08-23-2007 18:05:34
 Re: 41 (N Resistor Block in reply to Sean (TX), 08-23-2007 17:48:25
Sean..... .you've been posting and reading on this great N-Board for some time now. Why do you need conformation that YES, bypassing the infamous ballast resistor is gonna FRY yer points and MELT the gutts of yer squarecan ignition coil..... ..respectfully, Dell
Sean (TX)
08-23-2007 18:09:23
 Re: 41 (N Resistor Block in reply to Dell (WA), 08-23-2007 18:05:34
To weird that has not fried the coil yet??? I put some hours on it in the last year. Guess I better fix it. Darn hybred wiring harness!!
