I'm 99% certain that has a "semi-floating axle", with "C clip" axle retainers. There's NO pressing needed, and IIRC, no special tools. If that's correct, you have to drop the diffy cover, then remove the spider gear pin. Then, push the offending axle shaft INWARD, allowing the "C-clip" to fall out of the groove in the axle. Then, the axle can be withdrawn, and the seal popped out and replaced. The bearing is a "straight roller bearing". If it has not been making noise, and the rollers look good, and the wear surface on the axle shaft is good, you should NOT need to replace the bearing. Get a new bolt to retain the spider gear pin, and reassemble everything, and put the correct oil in the diffy. You probably might as well replace the other seal as well, they are less than $5.00, and once you have the spider gear pin out, it's not much more to pop the other axle, and do both. There's 2 seals used, depending upon HD or LD rear axle. HD rear axle, 8.8" ring gear uses National Seal #8835S. LD rear axle, 7.5" ring gear uses National seal #8660S.
