Addendum: Dell's Right, and About that Governor
A. Bohemian
08-24-2007 08:06:04
Take Dell's advice first. If you don't get the results you want, then come back to my post.
About that governor: I should have described the test more thoroughly. Start with the motor OFF. Grab the rod that controls the butterfly valve (throttle valve) on the carb. Move it back and forth; you should feel little resistance.
Now, start the engine; you should feel greatly INCREASED resistance.
