Grinding sound when braking
Phil_in_WA
08-24-2007 23:12:01
49 8N.
When I step on the right brake hard I get this horrible grinding sound. Doesn;t do it on the left brake.
Neither brake works all that well. Are you supposed to be able to freeze the wheel on the inside of a turn if you want?
Most concerned about the grinding sound though.
Thanks as always for the excelent advice.
Dell (WA)
08-25-2007 00:26:07
 Re: Grinding sound when braking in reply to Phil_in_WA, 08-24-2007 23:12:01
Phil..... .as you guessed, grinding is NOT GOOD. Could be NO BRAKE lining ...or... the spring centering stuff has come off their bracketts. Only way to tell is the dreaded brakedrum-removal for visual inspection and repair. Consult yer I&T FO-4 manual ($25, cheap) for how the return springs are supposed to be hooked up.
Yeah, I can LOCK up either left or right brake for sharper turns. Kinda diggs the pasture grass so I don't do if very often. Afterall, don't want my little sheepies to fall innna hole. According to the N-Owners manual, locked brake turning radius is 3-1/2ft based on centerline of rear axle. Outer front wheel radius is 8-ft..... .Dell
