Cryptkeeper
Cryptkeeper
08-25-2007 17:36:52
OK, still runnin', BUT now I need some CORRECT info on how to adjust the carb. It will idle OK, but from my understanding it is very complicated to adjust this puppy (8N).
Since I is a newbie, specific instructions would be GREAT!!
Thx Fellers
Britcheflee
08-25-2007 20:23:48
 Re: Cryptkeeper in reply to Cryptkeeper, 08-25-2007 17:36:52
As far as the other adjustment needle is concerned - this is the one facing the radiator - I had luck with the method told to me by an old guy who works on these 8Ns. Turn the adjustment out about 3 or 4 turns - then when the engine is warmed up get rpm up to about 1/2 or 3/4 speed. Gradually, a little bit at a time, with a few moments for the system to adjust, turn it back in...nowt will happen for a few turns but then it will start to cough and stumble...back it out again about 1/2 turn and let it settle down, then a tad more if needed. I discovered on mine that under load and high rpm mine was sputtering...I gave this needle another turn out and that fixed the problem.
Lee
soundguy
08-25-2007 21:36:41
 Re: Cryptkeeper in reply to Britcheflee, 08-25-2007 20:23:48
Idle jet is the side pointing jet..nearest the manifold mating flange.. Main jet is the big one that faces the radiator...
Soundguy
Tom N MS
08-25-2007 19:55:59
Dell's carb. adjustment instructions:I set the down-pointing mainjet to 1-12 turns and LEAVITT!!! then adjust the side-pointing idlemix for maximum idle rpms, NOT SMOOTHEST idle, MAX idle rpms. I then set the behind the carb idle-speed screw for SLOOOooow 400rpms idle. (ennythang under 500rpms is good) I do the idlemix adjust dance at least 3-times. Remember the side-pointing idlemix is BASSACKWARDS; out for lean, IN for ENRICH. My idlemix usually ends up about 38 turn. Yours will be different..... .....Dell
