Comments on this article on the internet re: burning oil.
Britcheflee
08-26-2007 04:26:33
Found this:
Link
Any truth in this article? Sort of tempting to give it a go and see what happens...
teddy52food
08-26-2007 08:19:17
 Re: Comments on this article on the internet re: burning oil in reply to Britcheflee, 08-26-2007 04:26:33
I read the article. This is common to see oil burning on a Chevvy engine after a valve job because the mechanic doesn"t know how to put the valve seals in right. By going to a heavier weight oil will help as adding STP will also. If it didn"t use oil before the valve job, it shouldn"t after either.
Tom N MS
08-26-2007 06:13:37
If I remember right, my Brother used this very thing in one vehicle andsaid it really did help but then used it in another one and it did nothing. Somehow I just have a hard time believing that it could deposit something on the cylinder walls that will stay there. But I'm not going to say I wouldn't try it in certain situations.
Britcheflee
08-26-2007 08:11:36
 Re: Comments on this article on the internet re: burning oil in reply to Tom N MS, 08-26-2007 06:13:37
Well, I am going to change up to a higher weight oil anyway so probably would not do any harm to bung some of this stuff in - if I can find it here in CA - I will report back - and if it works buy some shares in the company which produces it as all you guys will rush out and buy some!!!!
Some products no longer exist as they originally did here in Ca like the berrymans carb cleaner and I
discovered when I was re-staining my deck that the product Penofin was no longer available - apparently it had some stuff in it that actually worked so the guberment decided to ban it....I found the extra fingers I grew on my arm to be very useful too!!!
Lee
Dave H
08-26-2007 05:18:11
sounds like an add for snake oil to me.
like stated earlier, let us know if it works.
cargocult
08-26-2007 04:46:21
"Sort of tempting to give it a go and see what happens... "
Well, I read the whole thing...& I say GO 4 IT!! After all, it will only cost you a few $$ & if it gets u thru then it is good! If not..u are only out the few $$!! If it works, please report back here, as some of us may have engines that could use this procedure. CC
