Order Ford 8N Parts Online
Hauled in an 8N today
old
09-02-2007 13:33:54
I put a few pictures of it in the stuck and troubled area. Its not stuck any more and if all goes well it will also not be troubled much longer. The engine isn't locked up but the oil drain plug is missing. We would have loaded it with the starter but one of the back tires was so bad when we tried to do it the tire just let the rim spin inside of it so we had to winch it on instead. Yes the first thing I will do is fill the cylinders with tranny fluid since it has sat in the same place since back in the 60s. Then I figure put in a drain plug and fill with oil, clean the points and plugs and use my starting tank on it and see if it will run. I also know its a 195? since its a side mount. Has a 19-21 loader on it and part of a sherman back hoe also
Sean (TX)
09-02-2007 15:54:49
 Re: Hauled in an 8N today in reply to Indiana Jones, 09-02-2007 13:33:54
I would be mad to...Ill bet the plan was to come back and get the rest later. Complete 8N with sherman backhoe and dozier blade on ebay in OK. Its ugly but I bet it would clean up nice. Link
third party image
old
09-02-2007 16:20:17
 Re: Hauled in an 8N today in reply to Sean (TX), 09-02-2007 15:54:49
That sherman looks like its the same model as this on has. Going by the hyd controls and the hyd tank. I know as of now the tractor is a 1951 8N serail number 357675 and it has a model 54B100 sherman back hoe on it. I just did a finger compression check on it and only one cylinder has compression, probably valves stuck open so I will probably pull the head of of it. But I'll also probably see if it will run on one cylinder if so that might be enough to free up the other valves. I also know the front end loader works because when I was messing with it I pulled the lever and the loader is now up in the air all the way so thats a plus
Sean (TX)
09-02-2007 14:27:52
 Re: Hauled in an 8N today in reply to paulf, 09-02-2007 13:33:54
Looks like a good project. Whats hooked up to the back of it?
third party image
third party image
third party image
third party image
old
09-02-2007 15:25:05
 Re: Hauled in an 8N today in reply to Sean (TX), 09-02-2007 14:27:52
Thanks Sean for putting them up here. Whats on the back is what is left of a sherman back hoe. Some one stole the bucket and the bucket arm off of it at some time. The guy I got it from said one day they stoped to that house, they don't use it much and don't live there and those parts where gone. Sort of mad him mad and all but you know how that can be. Looked like they where tring to get it all but most have had some one drive by or something because you see whats left. Reason I say it looks like they where tring to get it all is because there are a few of the pins missing
