ignition switch
papahandyman
09-03-2007 04:43:15
can Any one tell me how to wire the key switch just 2 wires were do they go ? the way I hooked it up causes them to burn up
john hunt
09-03-2007 06:26:10
 Re: ignition switch in reply to papahandyman, 09-03-2007 04:43:15
how many keys on your key ring. they don't burn up they break.. take all the key off and leave one key on the key ring that all you need to start the tractor... my 8 n would go over a bump and it would died and if i did pick the key up it would stay runng ...
papahandyman
09-03-2007 05:11:39
8N
GB in MT.
09-03-2007 05:26:52
 Re: ignition switch in reply to papahandyman, 09-03-2007 05:11:39
third party image
This is the one before ser# 263844.
Let me know if ya need the one after that ser.#
Gary
papahandyman
09-03-2007 05:38:19
 Re: ignition switch in reply to GB in MT., 09-03-2007 05:26:52
Can you send the other diagram thanks
GB in MT.
09-03-2007 05:06:01
Need to know: 9N/2N, or 8N??? Then I'll post a diagram for ya.
Garythird party image
papahandyman
09-03-2007 05:16:59
 Re: ignition switch in reply to GB in MT., 09-03-2007 05:06:01
8N Thanks waiting for diagram
GB in MT.
09-03-2007 05:39:12
 Re: ignition switch in reply to papahandyman, 09-03-2007 05:16:59
third party image
This is the later 8N.
One of these should help ya.
Gary
papahandyman
09-03-2007 05:46:08
 Re: ignition switch in reply to GB in MT., 09-03-2007 05:39:12
They look the same to me mine is front mount dist. does that make any differance
GB in MT.
09-03-2007 05:58:38
 Re: ignition switch in reply to papahandyman, 09-03-2007 05:46:08
third party image
They are diff. If your 8N has a three post, terminal block, then you wire your 8N like the first diagram.
If it has a two post terminal block, then wire from the later 8N diagram.
If this is a 12Volt convertion, then you cannot use either diagram because these diagrams are Stock, 6volt, and they will not work on your wiring.
I don't mess with convertions.
Gary
papahandyman
09-04-2007 07:02:39
 Re: ignition switch in reply to GB in MT., 09-03-2007 05:58:38
Gary Turns out I had defective switch and a dead short at the terminal block all ok Thanks
GB in MT.
09-04-2007 07:05:46
 Re: ignition switch in reply to papahandyman, 09-04-2007 07:02:39
Glad it worked out for you. Thanks for letting us know, what it was.
Phil (NJ,Az,Sask)
09-03-2007 06:17:17
[quote]If this is a 12Volt convertion, then you cannot use either diagram because these diagrams are Stock, 6volt, and they will not work on your wiring.[/quote]
The wiring of the "ignition switch" will be the same for 6V or 12V systems, electrically the switch is between the LOAD side of the Battery and the ignition circuit. Those that convert should be starting from the OEM drawing's and only adding the changes.
JMHO
A. Bohemian
09-03-2007 09:05:15
 Verb Trouble in reply to Phil (NJ,Az,Sask), 09-03-2007 06:17:17
Surely Gary meant, "may not," not "will not." A simple mistake.
I know how he feels. I am always reluctant to try and help people with twelve-volt conversions.
I've never done one, and I've seen damn few of them done by inexperienced individuals that were not problematic.
Now, conversions done by professionals or people with electrical/electronics training are a completely different subject!
GB in MT.
09-03-2007 10:15:17
 Re: Verb Trouble in reply to A. Bohemian, 09-03-2007 09:05:15
A B;
At least someone knows what I was trying to say. Bad choice of words, on my part.
May, or may not work would have been much better.
Thanks
Gary
A. Bohemian
09-03-2007 11:10:34
 Mea Culpa in reply to GB in MT., 09-03-2007 10:15:17
I also expressed myself badly. I said, "...done by individuals with no experience..." when I meant "...DESIGNED by people with no experience..."
My apologies to all.
