Dual Powered
Sean (TX)
09-03-2007 10:34:32
Can this be done to a N series tractor?
third party image
Den N Ms
09-03-2007 16:55:26
 Re: Dual Powered in reply to Sean (TX), 09-03-2007 10:34:32
third party image
When farmers" demands for horsepower outpaced the manufacturers" designs, farmers would sometimes figure out ingenious tandem hookups. At Portland in August 2006, a John Deere 730 hooked in tandem with an 830 plowed a wide swath in one pass.
Sean (TX)
09-04-2007 11:28:18
 Re: Dual Powered in reply to Den N Ms, 09-03-2007 16:55:26
Pretty cool. I think the setup with no front wheels is by far the cooler setup :D
Sean (TX)
09-03-2007 11:49:08
 Re: Dual Powered in reply to ZANE, 09-03-2007 10:34:32
old said: (quoted from post at 14:37:03 09/03/07) Sure it can but it would take a few $$ to do so. I have seen one N series that had it done to it but they where side by side not in line with each other. Back when I lived in Mississippi I saw a good number of tractors hooked up that way, common down in the area I live in back in the 70s
Hobby farm
I saw the side by side one on tv a while back...That was interesting. I did some searching and could not find a photo of either setup.
old
09-03-2007 11:37:03
Dean
09-03-2007 11:25:44
Sean:
Of course. I have seen several versions of such dual tractors.
The most impressive that I have seen is a dual JD 830 diesel. Imagine four 6 1/8 by 8 1/2 cylinders (diesel) producing (conservatively) 85 HP per 2 cylinder engine at around 1150 RPM (pretty much all torque).
Something to see.
Dean
