Brake cleaner thru starter opening...other vehicles?
Britcheflee
09-03-2007 12:33:31
Would that trick of spraying brake cleaner through the starter opening work on other vehicles? My old IH truck was sitting for 20 years in a barn and although it starts and runs good I am having a devil of a job changing gears - grinds something awful going up and down the box - I think the clutch might be sticking and was wondering if the brake cleaner trick might work in this situation as well or is it just effective on the old tractors?
I try double declutching going up and down with little improvement and just changed out oil in gearbox and hi/lo transfer case with no improvement either.
Lee
Davie-d
12-22-2007 07:17:25
 Re: Brake cleaner thru starter opening...other vehicles? in reply to Britcheflee, 09-03-2007 12:33:31
Why did you leave it for 20 years and still want it to be OK?
Here is your punishment from GD of tracks.
old
09-03-2007 14:54:12
Yep it will work on any dry type clutch. On tht you will probably have an inspection plate you can remove under the truck and thats where you get to it
