Ill liven things up with an oil question...
Britcheflee
09-04-2007 03:24:51
It is hotter than hell here in Ca at the moment - and previously I put in a heavier multigrade oil - 30w50 I think. I am still getting some smoking on the 8N and was wondering - should I stay with a single weight oil or a multigrade oil and should I go with a higher wt oil in this hot weather.
Also, what happens if you mix various grade oils when topping up? I am assuming not much in these older engines.
What would be the highest grade engine oil you would feel safe running in the 8n? I dont mind going to a lower wt in the winter if need be.
Lee
Greg_Ky
09-04-2007 11:20:12
 Re: Ill liven things up with an oil question... in reply to Britcheflee, 09-04-2007 03:24:51
Kendall Nitro 70
TheOldHokie
09-04-2007 15:09:19
 Re: Ill liven things up with an oil question... in reply to Greg_Ky, 09-04-2007 11:20:12
Better hope it stays warm - the pour point of Nitro 70 is 16F. Below that it's a non-liquid, unpumpable, gelatinous crankcase full of dino jello. On the up side you won't have to worry about the smoke problem for long.
TOH
Lance in Brenham, TX
09-04-2007 07:49:53
Sounds like your using 20W50. Might want to try a straight 40W or add a stabilizer such as Lucas.
PhilipIN
09-04-2007 06:37:13
Also, search forum, there are many subjects pertaining to oil. Philip.
PhilipIN
09-04-2007 06:35:38
I use Mobil 1 5w-40 TDT for all wether protection. I am very satisfied with performance. Philip.
TheOldHokie
09-04-2007 04:42:54
A heavier oil will help restore oil pressure lost due to bearing and pump wear but it won't do much for worn rings.
TOH
ricko
09-04-2007 20:10:46
 Re: Ill liven things up with an oil question... in reply to TheOldHokie, 09-04-2007 04:42:54
Hey Old Hokie...can I get yer email address so I can see if I can get one of yer sleeve pullers?
TheOldHokie
09-05-2007 04:00:12
 Re: Ill liven things up with an oil question... in reply to ricko, 09-04-2007 20:10:46
Just in case you didn't get my mail message:
TOH's email
TOH
