2N rear tire, air valve, Replacement
GB in MT.
09-04-2007 06:54:28
While waiting for the primer to set up on the "N", I decided to check and replace the air valves on the rear tires, with new stainless steel valves. ( they have been in there for God knows how long!)
I took the lft. one out of the stem, and found it was already stainless, but replaced with new. Out and in, only 10 min.
When I took the rt. one out, only half of the stem came out. SURE, it was brass. So... now what I want to know is, Has anyone faced a 1/2 air valve stuck in their "N" tire tube nipple, and if so how did you get it out.
The local tire guy just wants to sell me a new tube, and pay him 38 bucks, just for the labor.!!! If I have to do that, so be it, But... there is nothing wrong with the tube I have, IF I can get this valve stem out.
Garythird party image
Sean (TX)
09-04-2007 17:38:58
 Re: 2N rear tire, air valve, Replacement in reply to 8N'r--WI, 09-04-2007 06:54:28
That is handy tool. I have one just like it in my tool box.
third party image
Hobo,NC
09-04-2007 17:57:59
 Re: 2N rear tire, air valve, Replacement in reply to Sean (TX), 09-04-2007 17:38:58
Air condition systems use the same schrader valve and for years used a tap and pliers to extract the broken valve till one day while I was look'n at the rusty 4&1 it hit me zackly what it was for. Felt sorta Dufus, not I have 3 or 4 of the 4&1 tools, I don't think it will break the bank to have a few on hand.
Hobo,NC
09-04-2007 17:32:10
 Re: 2N rear tire, air valve, Replacement in reply to GB in MT., 09-04-2007 06:54:28
I bet you have seen one of these but did not know what its for, now you do. Its the real deal, git one for just incase. werks rite well on AC valves to.
GB in MT.
09-04-2007 17:44:31
 Re: 2N rear tire, air valve, Replacement in reply to Hobo,NC, 09-04-2007 17:32:10
As a matter of fact I saw one today at the parts store. Didn't buy one, but saw it. I'll get one tomorrow morning, just cause you told me to.!!!third party image
Thanks Hobo.
GB in MT.
09-04-2007 11:44:57
Thanks for the replies.
Got it fixed for now. Took a dental pick tool, and run it down until it would fit inside the stem, then put a small hook on the end. I kept messing with it and pulling it out. The hook finally grab hold of the broken shank and I was able to get all but the very end of the parts out. Went down to the auto parts store and found some stainless valve extentions,with builtin stems. In stalled and walla!!, it takes and holds air. So..... I guess They are both good to go.
Now back to scraping Grease, so I can paint the 2N.
Little side trips, are not productive!!!!!
BCnT
09-04-2007 07:14:10
i've used a small cotter key and needle nose pliers to unscrew them if the top part is damaged.
GB in MT.
09-04-2007 07:20:32
 Re: 2N rear tire, air valve, Replacement in reply to BCnT, 09-04-2007 07:14:10
The top half screwed out nicely, the bottom half of the valve stem is stuck in there. I got the spring bottom out, but the stem, itself is still in there.
Gary
old
09-04-2007 07:53:53
 Re: 2N rear tire, air valve, Replacement in reply to GB in MT., 09-04-2007 07:20:32
If you have one of those valve core tools the little T looking thing. One end of it is made to pull out that problem part. Works about 50% of the time. If that doesn't work just take out the other part of the stem since rear tractir tubes have 2 piece stems and replace that part of the stem. Most good auto parts stores or tire stores will have them and you can also get them in stanless. Every rear tire I ever work on if the tube is bad I keep that part in my tire/tube parts draw and it has saved me big time over the years have extra ones laying around
