Order Ford 8N Parts Online
8N Stabilizer bars kit
Eriklane
09-04-2007 12:12:34
Wondering what a stabilizer kit does? Seeing them on Ebay. Do you remove the check chains?
Sean (TX)
09-04-2007 15:53:55
 Re: 8N Stabilizer bars kit in reply to Joe (IN), 09-04-2007 12:12:34
You can adjust the weight on the tail wheel with the top link. Have it to tight and the tail wheel will be airbourn.
Kenster
09-04-2007 14:09:25
 Re: 8N Stabilizer bars kit in reply to Ed S. (IL), 09-04-2007 12:12:34
Sean, do you still use your tailwheel with the chains? If so, does the tailwheel take much of the load? Seems like the chains would take all of the load and you wouldn't need the tailwheel.
Sean (TX)
09-04-2007 12:45:51
 Re: 8N Stabilizer bars kit in reply to Dan, 09-04-2007 12:12:34
third party image
Sean (TX)
09-04-2007 12:45:22
 Re: 8N Stabilizer bars kit in reply to Tennesseeguy, 09-04-2007 12:12:34
Here is a pic. I use limit chains with my shreder...
Sean (TX)
09-04-2007 12:43:03
 Re: 8N Stabilizer bars kit in reply to philm, 09-04-2007 12:12:34
They keep implements and lower lift arms out of your tires. Check chains stay on... I use stabilizer bars with my shreader,dirt scoop, rear blade and phd. Dont think they are used with plows...
