Thanks to all you folks for the reply. I will try to expand and answer all your questions. I have a 49' 8N, 12V system w/front mount distributor, electronic ignition, late model governor w/tachometer. Installed new plugs, new plug wires (resistor type to go with the electronic ignition), new distributor cap and new 12V, 2.5 ohms coil. Voltage to coil is 8-9V @ 1200 RPM. The distributor seems to be in good mechanical condition with no play. Get a strong (3/16") blue spark on all 4 with tester and a good spark on all the new plugs also. The 1-2-4-3 wiring is correct.What I meant when I said that it is running on one cylinder only, is this: I take wire plugs 2-3-4 out, one at a time. When I do this, the engine doesn't seem to change the RPM, but if I take #1 out, it dies. I tried this test again today, but with 2-3 and 4 totally disconnected from the plug, guess what? It runs. Not only that, it starts with one cylinder, (of course if I put in gear, It dies). Also I checked the plugs after I stop the engine, and 1 and 2 are dry and 3 and 4 are wet. The electronic ignition has been on the tractor for about a year with out any problems. if I get a good spark on all cylinders, I don't know how to single out the electronic ignition . As far as the compression test, I don't know if I was off or the tester was off. In any case the compression was even on all four, well above 100 psi. I can't retake it today because the hood is back in. I have to get me one of those elbow adapters. I hope I have given enough detailed description of my problem for you gurus to make any sense. I always appreciate your help. MauNC
