Order Ford 8N Parts Online
1951 8N progress report. part 3
old
09-06-2007 09:14:41
Well it now runs on all 4 cylinders most of the time. One exhaust valve sticks off and on. Also seems like every time I try to start it up I have to prime the oil pump or I have no oil pressure and I still have an oil leak seems to be comeing from the pan gasket. So I figure I'll end up taking the loader off and then dropping the oil pan to see why I loose prime and also so I can replace the pan gasket and maybe stop the oil leak. Oh well still not all that bad since we only payed $100 for it
Colin King
09-06-2007 10:20:12
 Re: 1951 8N progress report. part 3 in reply to old, 09-06-2007 09:14:41
haha! A $100 bucks, eh? How could you go wrong with that. The loader's probably worth more than that ;-)
Sounds like you're making good progress. Oil pump rebuild down the road, though? What's the oil pressure like?
Colin
old
09-06-2007 10:36:36
 Re: 1951 8N progress report. part 3 in reply to Colin King, 09-06-2007 10:20:12
Oil pressure when running is over 20PSI hot or cold. I don't have the cooling system working at this time so I can only run it 5-10 minutes if even that long. Fan belt if gone and theres no genny or alternator on it. Yep I figure the loader is worth around $200-300 since I know for sure it works good and doesn't leak down even after being up since sunday. Pump on the loader looks almost new even though I know its 30 plus years old
GB in MT.
09-06-2007 09:29:37
Next thing, you will tell us is, that you are thinking of makin' a TRAILER QUEEN out of it.third party image
Keep workin' on it, That may not be far fetched.
$100, for it?? My god man, ya stole it!!!!
Garythird party image
old
09-06-2007 10:39:05
 Re: 1951 8N progress report. part 3 in reply to GB in MT., 09-06-2007 09:29:37
Nope never will be a trailer queen as long as I own it. Now maybe when and if some one else buys it from me who knows. I got it cheap because the guy knows me and knew I would get it back up and running or use it to get others up and running.
