Order Ford 8N Parts Online
8N transmission
Russel Lueras
09-09-2007 06:15:09
I have a 8n tractor. I was using it and it became stuck in 1st gear. I opened up the top and got it to nuetral. But even in nuetral you can push the tractor and it rolls a little ways then stops like it is trying to pop into gear. Or if you drive it it shifts gears fine but makes a loud clunking noise. Please HELP
chucktn
09-12-2007 09:57:49
 Re: 8N transmission in reply to Russel Lueras, 09-09-2007 06:15:09
Drop a little oil and look at your second gear. Had the same problem it would roll then lock up. I had a couple of broken teeth that was causing it to bind. Couldn't see if very well because of where it was and the oil. Finally had to split the tractor at the front to fix it.
thomas seaman
09-09-2007 07:04:25
it sounds like some thing gave could a bearing or anything but check the oil level try pulling the plug to let the oil out look for metal stick your finger try to feel for loose parts
