2N starter problem
rd99
09-09-2007 10:46:43
I went out to start my '47 2N.
I pressed the starter button and the engine turned over normally I though it was about to start but it didn't.
I pressed the starter button again and nothing happens, I don't hear any noises other than the click of the button itself (I can't tell if it's a relay click or just the click of the button bottoming out). I haven't gotten out my shop manual yet to start going through the steps, but does anyone have any pointers?
soundguy
09-10-2007 08:03:40
 Re: 2N starter problem in reply to rd99, 09-09-2007 10:46:43
In addition to what the others siad.. when it didn't start on the previous attempt. the starter drive may hve hung in the ring gear.
soundguy
Bruce (VA)
09-09-2007 17:42:30
Ditto what old & Bob said, and while you are cleaning all the grounds & cables, charge the battery.
old
09-09-2007 11:28:13
You probably have a bad connection some place. Check/clean all battery connections amd cables connections
Bob
09-09-2007 11:18:27
Check ALL connectionns, and the battery, for charge.
Unless the 2N has been "modded", it doesn't have a solenoid, just a mechanical switch.
