Tranny hole???
Cryptkeeper
09-09-2007 11:20:40
OK Fellers, got mine runnin' but it appears I have a 41 9N or early 42. I would like to know why there is a hole in the transmission, right side, behind where the rear tie rod (rag link) attaches. Seems to have a grommet in the hole ('bout 1/2" dia). My F0 4 doesnt show any pics with a hole there???
I'm sorta lost.third party image
KCM
09-09-2007 21:29:20
 Re: Tranny hole??? in reply to Cryptkeeper, 09-09-2007 11:20:40
Shermans were always on the left side. Most likely is a Hupp, but also could be an F&T. All aux trannys were dealer installed and will not be in the FO-4 manual. Hupp had an overdrive/direct and an over/direct/underdrive. They look the same from the outside. Take at look at the site below which shows both. The lever that Red Rock sells is for the over/direct/underdrive which shifts much like the Sherman over/direct/underdrive. I would suspect with such an old tractor it likely just had the over/direct, but you never know.
Cryptkeeper
09-09-2007 12:47:33
Thx Sean, just what I need! Know where I can get an assembly drawing for this ole Hupp?
Thx in advance. third party image
Sean (TX)
09-09-2007 12:34:39
 Re: Tranny hole??? in reply to Tom N MS, 09-09-2007 11:20:40
You can get the parts at Red Rock...
Red Rock Manufacturing
Cryptkeeper
09-09-2007 11:59:38
Thx Bob, looks like I have a Hupp xmission added to this Puppy. There is no lever,, just a hole with a spline or something about 1/2" inside the grommeted hole. Any body know where I can get parts to extand this shaft/lever??
Thx guys, I knew somebody on this forum would know what it was!!
Bob
09-09-2007 11:27:51
Punch the link below, and scroll about half-way down to the HUPP section. Some versions of the Sherman MAY have had the hole in a similar area.
